0 members (),
134
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | what a pain in the*%#& to try and fire off my 54'burb by myself with that factory starter setup.what is involved in doing a upgrade to the starter with solinoid mounted directly to it like a modern gm starter.this burb isn't stock and i would much rather just turn the key. was it 60' when they finally got rid of that bs.foot pedal? i really like being able to use my remote starter when i'm checking the engine and carb settings.thanks  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | cars had solenoid starters back then, just hafta find a starter your voltage and install a car ign sw ..... but the foot stomp can be activated from under the hood using a large screwdriver or other bar between the floor and the button, cheaper Bill | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | i do like the cheaper part! it seems that whenever i'm trying to get a old motor fired off i can usually count on carb problems(dirt) and if i could use remote starter i can stand close to carb. my remote switch has foot operated option,custom feature to free up both hands. used a old sewing machine foot pedal a mounted switch. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just an observation....your 54 engine, if original, is running a 6 volt 139 tooth flywheel with a 6 v footstomp starter. Your 59 if stock, is a 12v 168 tooth flywheel.....a 59 solenoid controlled 12v starter will not work on your 54 6v flywheel. And BTW...a footstomp starter in the cab draws as much attention as a pair of carbs.....
Once you get your T5 installed along with the appropriate Holley/Weber or a pair of Carter/Webers you'll rarely need to be under the hood making adjustments. You'll be out cruising the streets of Tacoma and enjoying driving your Burb!!!!!!!!!!!!
Dave | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | see
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=002117#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=001310#000012
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | my goal is the "UNFINISHED NATIONALS" in elma wa. at the end of summer. if the beater burb of tacoma makes 1 show i will be happy.it's been off the road for 20+ years, it's gonna be like a cheap re-make of "FRANKENSTEIN LIVES" | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If you get it running lets meet in McCleary so we can park your Chevy and my GMC Suburban next to each other...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | IF! the only reason it won't happen is if my health take a wrong turn. the only thing good that came from my poor health is my computer skills have improved. i still don't know how anyone(unless it's their job) can spend endless hours on the computer.getting out and cutting and grinding improves my mental health. i need some quality shop time. see you in McLeary steve! | | | | | Joined: Apr 2004 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 72 | Micron, you got any pics of your Burb? I would like to see some. Here is a link to mine. http://rides.webshots.com/album/399787138YEcinr?vhost=rides
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | i will post some soon on webshots. nice metal work! i need to kick it into a higher gear on mine.health issues limit me on my progress, my problem is i over work myself getting plenty done but pay for it 3 days later. if i get it to safely drive around by the end of summer i will be satisfied. it was purchased in may 2007 so if it motors around in 90 days that is fine by me. | | |
