2 members (Hanks custodian, 1 invisible),
124
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 37 Apprentice | | Apprentice Joined: May 2007 Posts: 37 | Have any of you welded your rear doors up and made a hatch lift door. I am curious if any of you were able to make it work with the drip rails still intact, on my 56 ford panel I removed the drip rail so I could make it operational but have been told after the fact that there are some who have done it without removing the drip rails, what type of hinges have you Chevy guys used for this modification? | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Hey, I just replied to your other post. I'll try to find pics of my old '56 Ford Panel and post them. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | A budy of mine did it on a '55 2nd Chevy panel. If I remember correctly he used hinges from a mini-van.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | I have thought about it several times as the PO welded my top half hinges and they are not aligned correctly. A hatch door was in the Classic truck mags awhile back. I'll try to go dig it out.If anyone has any pictures of actual installation it would be great. I also posted ad wanted in Swap area if anyone knows where a clamshell might be located.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | I have thought about it too but... wouldn't it be an extremely heavy door ? Can't think of any way to put a spring or whatever to help with the lift either. Ter | | |
