3 members (WICruiser, TUTS 59, Otto Skorzeny), 56 guests, and 1 robot.
Topics128,049
Posts1,055,684
#24716 03/16/2004 6:39 AM
I was cleaning up my rear end today that i plan on putting on my truck and noticed that it had some oil leaking around the weld where the axle housing and the differential meet together. It isn't where the housing slides into the differential but on the welds that are through the cast onto the housing. I'm not sure if I am describing this well enough but it just don't look like the factory is holding up. Any help would be appreciated.
#24717 03/16/2004 3:42 PM
ara you sure it's not just "weeping" around the cover and "wicking" along the weld? - seems unlikley the weld would spring a leak after many years, as a weld is usually stronger than the surrounding metal - clean it all well including wiping down w/ solvent and watch for awhile [or put some thin oil or even solvent in temporarily and see if it leaks] axles tend to collect grimy buildup over time regardless of how well sealed they look
