2 members (N-man, 3800GUY),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,724 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | does any one know if the studs on a frame mount tank straps and a cab mount tank the same length. i need to replace the ones on my burb and i have some truck studs | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | John,
What is the total length of you cab-tank stud and what is the length of the threaded section on that stud?
My suburban studs were broken, so I have no idea of the correct length. I made studs and cut them to length by test fitting (and trimming the length as needed). I decided not to use rivets to attach the stud to the strap; I used small round/headed bolts.
Tim | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | overall length is 3 1/8 inches | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | the threaded length is 1 1/4 inches | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | John,
That sounds about right. I will measure the stud this afternoon/evening and post a reply.
Tim
It looks line mine are about 4" total length with about 2.5" threaded. I will make a more exact measurement tomorrow. | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | thanks tim i also like your website i also have a 54 3100 deluxe cab | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | the studs are the same it worked | | |
