0 members (), 103 guests, and 4 robots.
Topics128,095
Posts1,056,494
Members48,444
does any one know if the studs on a frame mount tank straps and a cab mount tank the same length. i need to replace the ones on my burb and i have some truck studs
1949 SUBURBAN
ttt
1949 SUBURBAN
John,
What is the total length of you cab-tank stud and what is the length of the threaded section on that stud?
My suburban studs were broken, so I have no idea of the correct length. I made studs and cut them to length by test fitting (and trimming the length as needed). I decided not to use rivets to attach the stud to the strap; I used small round/headed bolts.
Tim
overall length is 3 1/8 inches
1949 SUBURBAN
the threaded length is 1 1/4 inches
1949 SUBURBAN
John,
That sounds about right. I will measure the stud this afternoon/evening and post a reply.
Tim
It looks line mine are about 4" total length with about 2.5" threaded. I will make a more exact measurement tomorrow.
thanks tim i also like your website i also have a 54 3100 deluxe cab
1949 SUBURBAN
the studs are the same it worked
1949 SUBURBAN
