0 members (),
126
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 8 New Guy | | New Guy Joined: Mar 2007 Posts: 8 | Hello ,I was wanting to know the bolt pattern on my new 62 chevy suburban ,I haven"t had any time to retrieve it from out of town .One other question is does any one know if i wanted to put that body on a newer modern chassis what would be close to the original? Thanks for all of your help fellow stovebolters.Curtis | | | | | Joined: Dec 2006 Posts: 34 Apprentice | | Apprentice Joined: Dec 2006 Posts: 34 | It should be 6 x 5.5" at least that is what it is on my 62 gmc, as far as the frame goes anything from 63 to 72 should work real well. My self I am just going to update the front cross member to a early eightys unit with disc brakes should bolt right up.Do you need to replace the whole frame or are you just looking to update the suspension?
it's not how much time you spend on it, it's how you spend your time with it
| | | | | Joined: Dec 2006 Posts: 34 Apprentice | | Apprentice Joined: Dec 2006 Posts: 34 | the bolt pattern is 6 lugs with 5.5" spacing 15" wheel
| | | | | Joined: Jun 2007 Posts: 1 Junior Member | | Junior Member Joined: Jun 2007 Posts: 1 | Can anyone tell me what the largest tires and wheels you can put on a 66 suburban that is 6 lug without cutting anything Thanks for any and all help. 66burb | | |
