0 members (), 191 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
#246964 04/05/2007 2:30 PM
Hello ,I was wanting to know the bolt pattern on my new 62 chevy suburban ,I haven"t had any time to retrieve it from out of town .One other question is does any one know if i wanted to put that body on a newer modern chassis what would be close to the original? Thanks for all of your help fellow stovebolters.Curtis
Apprentice
Apprentice
It should be 6 x 5.5" at least that is what it is on my 62 gmc, as far as the frame goes anything from 63 to 72 should work real well. My self I am just going to update the front cross member to a early eightys unit with disc brakes should bolt right up.Do you need to replace the whole frame or are you just looking to update the suspension?
it's not how much time you spend on it, it's how you spend your time with it
Apprentice
Apprentice
the bolt pattern is 6 lugs with 5.5" spacing 15" wheel
Junior Member
Junior Member
Can anyone tell me what the largest tires and wheels you can put on a 66 suburban that is 6 lug without cutting anything Thanks for any and all help. 66burb
