2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#246627 01/19/2007 3:35 AM
Hi All,
On the inside of the cargo space of my 54 panel are 4 sets of 2 bolt holes. These holes are located on the flange that connects the roof to the body. The flange indents to accomodate whatever connected to these holes. There are 2 sets of 2 holes on each flange. Does anyone know what these bolt holes are for? As always, Thanks
All the best, Ted
#246628 01/19/2007 3:56 AM
2 of the "headliner bows"?
#246629 01/19/2007 4:23 AM
Thanks for responding red58, I need some definitions here. If head liner bows are those ribs that support the roof, then no, these holes are not for them.
All the best, Ted
#246630 01/19/2007 4:36 AM
Hi Ted, i think the holes youre referring to are the ones that are abt. half way up the side support brackets.(between the roof panel and bottom sides?) If thats them, there was originally a 1"x3" piece of oak that was a cargo tie down.
I can send you pics. of mine for verification if that'll help.
Marty
#246631 01/19/2007 5:03 AM
aahhh, yes, Marty's got it - I thought you meant on the flange that goes around right up at the top
#246632 01/19/2007 5:06 AM
Thank you delux54panel but NO these holes are up high right at the roof / body flange. My truck still has the oak tie down bars so I know what you were getting at. I need to learn how to post a picture.
I guess we will have to make this a contest.
Speaking of pictures I would love to see your panel.
All the best, Ted
#246633 01/19/2007 5:35 AM
Hi Ted,,Those holes are what they used to bolt the roof panel down to the body sides.
Ive sent you pics of my panel and my '54 pick up to your e-mail add.
All the best,Marty
#246634 01/19/2007 5:55 PM
NOPE, these sets of holes are horizontal and are directly opposite each other suggesting that a bracket once existed there maybe spanning the cargo space, like a closet hanger bar.
These holes are well done suggestintg that it may be factory but maybe not. It's obviously no big deal since you guys seem unfamiliar with it. Thanks for the pictures Marty those are 2 spectacular trucks. I'll send you some pics of mine in progress.
All the best, Ted
#246635 01/25/2007 11:03 PM
I have a piece of wood from my 47 1/2 panel. It was mounted across the top of the cargo area, just behind the front seat. It has an L-bracket at each end that mounts to the truck with two bolts each. the wood looks like a 1x4 that was cut to match the curve of the top of the van. I think it's oak, and it's painted grey same as the interior. It wasn't attached when I got the van, but I kept it anyway.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
