| | | Forums66 Topics128,211 Posts1,057,477 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I'll be honest--I haven't climbed under my '62 Suburban to really take a long hard look at this problem. Every time I go under the truck, it's for something else. When it rains, I'm noticing the floor getting damp around the flange for the wheel tubs, and a couple other places. Overall, the floor in my truck seems pretty solid. I haven't noticed any soft spots at all, at least from the top. I really, really don't want to replace the floor, at least not for the next several years. Did the factory apply any seam sealer where the floor meets the metal joints? Have any of you guys expericnced this weeping? What have you guys done to solve it?
Thanks, Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Mar 2005 Posts: 37 Junior Member | | Junior Member Joined: Mar 2005 Posts: 37 | I don't recall there being any sealer there but a friend of mine had the same problem and we tore into it one day only to find the wood had began to dry-rot and was crumbling away from the metal.He later replaced the wood.
BAN LOW PERFORMANCE DRIVERS... NOT HIGH PERFORMANCE CARS !!
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | some years there was a 'mastic' of sorts where the metal sat on the wood - you might be able to deal with it by undercoating around the edges of the wood floor from below, or maybe the wheel tubs could be pulled and some sealer applied from the top
Bill | | |
