9 members (JoergK., Bill Hanlon, J Lucas, Chip O, dt235sd, Gdads51, Hotrod Lincoln, 2 invisible), 75 guests, and 0 robots.
Topics128,205
Posts1,057,427
Members48,471
I'll be honest--I haven't climbed under my '62 Suburban to really take a long hard look at this problem. Every time I go under the truck, it's for something else.
When it rains, I'm noticing the floor getting damp around the flange for the wheel tubs, and a couple other places.
Overall, the floor in my truck seems pretty solid. I haven't noticed any soft spots at all, at least from the top.
I really, really don't want to replace the floor, at least not for the next several years.
Did the factory apply any seam sealer where the floor meets the metal joints? Have any of you guys expericnced this weeping? What have you guys done to solve it?
Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
Junior Member
Junior Member
I don't recall there being any sealer there but a friend of mine had the same problem and we tore into it one day only to find the wood had began to dry-rot and was crumbling away from the metal.He later replaced the wood.
BAN LOW PERFORMANCE DRIVERS...
NOT HIGH PERFORMANCE CARS !!
some years there was a 'mastic' of sorts where the metal sat on the wood - you might be able to deal with it by undercoating around the edges of the wood floor from below, or maybe the wheel tubs could be pulled and some sealer applied from the top
