1 members (Otto Skorzeny), 85 guests, and 1 robot.
Topics128,162
Posts1,056,941
Members48,458
does anyone have a source for the studs that are riveted on the end of the gas tank straps. I did not want heat them up with the torch when i removed the tank and they broke.
1949 SUBURBAN
John, I would just use a piece of grade 5 or 8 threaded rod the right length, warm it to cherry red and flatten it with a hammer as original. Then you can drill for bolts or rivets as original. When I removed mine I ground a lot of the original nut away then split it open.
thanks splashoil, how long are the studs overall
1949 SUBURBAN
