0 members (),
135
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | does anyone have a source for the studs that are riveted on the end of the gas tank straps. I did not want heat them up with the torch when i removed the tank and they broke. | | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | John, I would just use a piece of grade 5 or 8 threaded rod the right length, warm it to cherry red and flatten it with a hammer as original. Then you can drill for bolts or rivets as original. When I removed mine I ground a lot of the original nut away then split it open. | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | thanks splashoil, how long are the studs overall | | |
