2 members (Uncles51, Lostbuthaulinass), 79 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#24611 11/14/2003 11:13 PM
I need to know if I can swap out the backplates and drums on the front of my 65 4x4. The front axle has been changed to a 60-63 GMC and I can't find the right brake parts for it so I thought I'd swap in newer parts for easier work later down the road. Any help is appreciated Thanks
Cliff
#24612 11/15/2003 8:14 PM
I think the backing plate assemblies will bolt on
Have you thought about changing over to the open knuckle design front axle and going with the disc brake set-up?
