0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24611 11/14/2003 11:13 PM | Joined: Nov 2003 Posts: 13 Member | | Member Joined: Nov 2003 Posts: 13 | I need to know if I can swap out the backplates and drums on the front of my 65 4x4. The front axle has been changed to a 60-63 GMC and I can't find the right brake parts for it so I thought I'd swap in newer parts for easier work later down the road. Any help is appreciated Thanks
Cliff | | |
#24612 11/15/2003 8:14 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I think the backing plate assemblies will bolt on - - Have you thought about changing over to the open knuckle design front axle and going with the disc brake set-up?
