8 members (Gdads51, 2-Ton, Naturalthud, DoubleB, Barney1951, Hotrod Lincoln, Hanks custodian, 1 invisible),
120
0
Mod | | | Forums66 Topics128,081 Posts1,056,070 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Hi guys; Hope to bum some information from someone! I recently saw the remains of a 1949 AD panel and it still has some of the fancy stainless trim. The fender spears and trim seem pretty straight forward (ie just small bolts through the fenders) but how are the two pieces around the barn door windows attached? (or removed!!) The doors are rusted or jammed shut and I can't see real well inside. I really don't want to butcher them getting them off!! I hope to get back there soon before this hulk gets hauled away to the crusher. Can any one help? Thanks Ter | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Just cut the panel out around the trim using Sawzall, torch, snips, hammer & chisel, what have you. Brian | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | those trim pieces are held on with spring clips. very gently slip a screwdriver under the trim and pry up,,it'll come loose. or,,,if you wanna hack up the inside of the door,you can push them out from the inside. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | but how are the two pieces around the barn door windows attached? (or removed!!) I agree with delux54panel but you might want to use a heavy putty knife to "spread the load" to help to prevent nicks in the stainless trim. This is how the trim was removed from my suburban. Restoration Specialties sells a exact-size replacement clip for the trim round the rear door windows. | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | You know that Panel trucks that accepted that barn door window trim were factory prepared with the proper mounting holes around the windows. You're going to have to drill you doors to make these fit. | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Ter...by the way, better rush to rescue that trim...that stuff sells for almost $2K US. Good luck | | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Thanks for the replies. I will have to pass on the sawzall hint as the truck is a long way from electrical outlets!! I am real keen to get the trim but it is not all there.. the lower part of the truck is a bit "shredded" from driving through rocks or deep ditches or something!Reminds me of a Model T Ford I saw years and years ago that was towed behind a tractor across a field instead of a harrow!!
Thanks again Ter | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | dewalt makes a nice 18 volt sawzaw. | | | | | Joined: Apr 2004 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 34 | The mounting holes for these stainless trim pieces on the Panel Barn Doors are actually rectangular slots. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by steveg: that stuff sells for almost $2K US. Wow! Where have you seen it go for that much? I've never considered selling my set until now...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Old Sub....absolutely...this stuffs like gold...I've sold three pieces on ebay (right rear) of the ss trim for over $500. Last set I followed, 12 pieces went for about $2K on ebay...and that's without the fender spears! I sold two significantly damaged fender spears last month for almost $500. on ebay. Demand is unbelievable... | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Steve, I sold the trim from my '52 1 ton panel, back during the Summer, for over 2K. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | ive got an extra set and a half..... took it to a swap meet once and you'da thought i brought gold nuggets. (for the right price,,,,its for sale) | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Guys anyone have a picture of what it looks like? on the truck ?Never seen it but do know of a graveyard that might have some. Thanks
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Check out the link to my Webshots Albums, at the bottom of this post. You'll see my panel truck before the trim was removed. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | check out my panel in the gallery,,,"marty flores' 54 panel truck". it has the deluxe trim. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
