6 members (FishinToms53, UtahYork, Toadwart, Southerntruck, homer52, 1 invisible), 63 guests, and 2 robots.
Topics128,087
Posts1,055,999
Members48,430
#246091 10/12/2006 3:04 PM
Ter
Offline
Hi guys;
Hope to bum some information from someone!
I recently saw the remains of a 1949 AD panel and it still has some of the fancy stainless trim. The fender spears and trim seem pretty straight forward (ie just small bolts through the fenders) but how are the two pieces around the barn door windows attached? (or removed!!)
The doors are rusted or jammed shut and I can't see real well inside. I really don't want to butcher them getting them off!!
I hope to get back there soon before this hulk gets hauled away to the crusher.
Can any one help?
Ter
#246092 10/12/2006 3:22 PM
Just cut the panel out around the trim using Sawzall, torch, snips, hammer & chisel, what have you. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#246093 10/12/2006 6:41 PM
those trim pieces are held on with spring clips. very gently slip a screwdriver under the trim and pry up,,it'll come loose. or,,,if you wanna hack up the inside of the door,you can push them out from the inside.
#246094 10/12/2006 7:49 PM
Quote
I agree with delux54panel but you might want to use a heavy putty knife to "spread the load" to help to prevent nicks in the stainless trim. This is how the trim was removed from my suburban.
Restoration Specialties sells a exact-size replacement clip for the trim round the rear door windows.
#246095 10/14/2006 1:18 AM
You know that Panel trucks that accepted that barn door window trim were factory prepared with the proper mounting holes around the windows. You're going to have to drill you doors to make these fit.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
#246096 10/14/2006 1:20 AM
Ter...by the way, better rush to rescue that trim...that stuff sells for almost $2K US. Good luck
Steve G.
#246097 10/21/2006 11:16 PM
Ter
Offline
Thanks for the replies.
I will have to pass on the sawzall hint as the truck is a long way from electrical outlets!!
I am real keen to get the trim but it is not all there.. the lower part of the truck is a bit "shredded" from driving through rocks or deep ditches or something!Reminds me of a Model T Ford I saw years and years ago that was towed behind a tractor across a field instead of a harrow!!
Thanks again
Ter
#246098 10/22/2006 2:37 AM
Z
Z Offline
dewalt makes a nice 18 volt sawzaw.
#246099 10/22/2006 2:48 PM
The mounting holes for these stainless trim pieces on the Panel Barn Doors are actually rectangular slots.
#246100 10/22/2006 5:02 PM
Quote
Wow! Where have you seen it go for that much? I've never considered selling my set until now...
#246101 10/30/2006 1:36 AM
Old Sub....absolutely...this stuffs like gold...I've sold three pieces on ebay (right rear) of the ss trim for over $500. Last set I followed, 12 pieces went for about $2K on ebay...and that's without the fender spears! I sold two significantly damaged fender spears last month for almost $500. on ebay. Demand is unbelievable...
Steve G.
#246102 10/30/2006 2:10 AM
Steve, I sold the trim from my '52 1 ton panel, back during the Summer, for over 2K.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#246103 10/30/2006 6:40 AM
ive got an extra set and a half..... took it to a swap meet once and you'da thought i brought gold nuggets. (for the right price,,,,its for sale)
#246104 10/31/2006 2:51 AM
Guys anyone have a picture of what it looks like? on the truck ?Never seen it but do know of a graveyard that might have some. Thanks
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
#246105 10/31/2006 2:58 AM
Check out the link to my Webshots Albums, at the bottom of this post. You'll see my panel truck before the trim was removed.
Spanky Hardy
1950 GMC 250 1-Ton
#246106 10/31/2006 5:51 AM
check out my panel in the gallery,,,"marty flores' 54 panel truck". it has the deluxe trim.
#246107 10/31/2006 1:00 PM
