| | | Forums66 Topics128,203 Posts1,057,412 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | Hi all.....got a 63 burb project...looking for an exhaust sytem or bend #'s so I can make a matching other side...want dual exhaust.. cant find info on pipe up to manifold in system books...also need a fourspeed shifter....have some extra parts let me know what yer lookin fer. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Dthela, any good muffler man can bend up duals-is there any way you can get the frame to a local muffler shop? I am almost sure duals were not offered "factory" for the V6 so there may not be bend charts. Brian | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | one side should be the same as the other...cant geyt frame to shop | | | | | Joined: Apr 2000 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2000 Posts: 81 | You could tell a muffler shop you have a shortbed stepside pick up truck. I believe your wheel base is 110", a 67 thru 72 should be the same. I have a 62 or 63 GMC parts truck with the stock 4 speed setup still in it. I could use a better pair of tail lights for my 62 burb. Mike
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe 1947 Chev Coupe 1969 GTO ragtop
