2 members (Maybellene, Steelonsteel), 125 guests, and 2 robots.
Topics128,196
Posts1,057,393
Members48,469
#246002 09/24/2006 12:15 AM
Hi all.....got a 63 burb project...looking for an exhaust sytem or bend #'s so I can make a matching other side...want dual exhaust.. cant find info on pipe up to manifold in system books...also need a fourspeed shifter....have some extra parts let me know what yer lookin fer.
#246003 09/24/2006 1:50 AM
Dthela, any good muffler man can bend up duals-is there any way you can get the frame to a local muffler shop? I am almost sure duals were not offered "factory" for the V6 so there may not be bend charts. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#246004 09/24/2006 5:13 PM
one side should be the same as the other...cant geyt frame to shop
#246005 09/26/2006 10:06 AM
You could tell a muffler shop you have a shortbed stepside pick up truck. I believe your wheel base is 110", a 67 thru 72 should be the same. I have a 62 or 63 GMC parts truck with the stock 4 speed setup still in it. I could use a better pair of tail lights for my 62 burb. Mike
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe
1947 Chev Coupe
1969 GTO ragtop
