2 members (Johnnydog, 78buckshot), 60 guests, and 2 robots.
Topics128,060
Posts1,055,832
#245951 09/10/2006 5:39 AM
1 Offline
folks, can you put a 52 frame under a 56? both are panels(3100's) both are chevys and have 116" wb.thanks
#245952 09/10/2006 1:50 PM
Without serious modifications, I don't think you'll be able to mount the '56 on the '52 because of the body mounting location and body width.
#245953 09/10/2006 2:51 PM
totally different critters, and actually the 56 panel WB is 114", 52 prolly is as well
you can use any 55-59 short frame for a 56 panel if you have the panel body mounts and the frame horn extensions for the rear [which the pu doesn't have]
#245954 09/10/2006 4:01 PM
Quote
...the frame horn extensions for the rear [which the pu doesn't have]
The frame horns are to mount your rear bumper...which btw, I have a pair if anyone is looking.
