| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | folks, can you put a 52 frame under a 56? both are panels(3100's) both are chevys and have 116" wb.thanks | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Without serious modifications, I don't think you'll be able to mount the '56 on the '52 because of the body mounting location and body width. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | totally different critters, and actually the 56 panel WB is 114", 52 prolly is as well
you can use any 55-59 short frame for a 56 panel if you have the panel body mounts and the frame horn extensions for the rear [which the pu doesn't have]
Bill | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | ...the frame horn extensions for the rear [which the pu doesn't have] The frame horns are to mount your rear bumper...which btw, I have a pair if anyone is looking. | | |
