4 members (fonz8261, Hotrod Lincoln, TexasJim50, 1 invisible), 94 guests, and 2 robots.
Topics128,134
Posts1,056,416
Members48,441
#245865 08/21/2006 3:13 PM
Hello to all,
I am looking for recommendations for tires a '46 Carryall/Suburban. I have 16" artillery wheels for it. I'd like to be able to drive everywhere not just to cruises/shows. Wide whites would be nice but handling is of a higher priority than looks. On a side note, were the wheels genreally painted the same as main body color? Thanks for any good words from you all, Patrick
Richard J Patrick - 1946 Suburban
#245866 08/22/2006 8:55 PM
Those artilleries are pretty skinny for radials. Why not have two sets, one with your wide whites and artilleries and second a bit wider for radials. Caution though, if you get to wide at all up front the radials will contact the tie rod ends. There are lots of wheel shops around that can make up just about anything you want and not to expensive.
1946 1/2-Ton Chevy
#245867 08/23/2006 10:11 PM
Are the 16" rims not a good one to use? They are original to 1946 aren't they? Or is it more advantageous to use the 15" rims? Confused, but trying. Patrick
#245868 09/10/2006 1:48 AM
I know 15 inch artillery wheels were an option for 39-46 GMC 1/2 ton trucks and I believe they were for Chevy as well. 16 inch wheels are 4 1/2 inches wide and the 15 inch are 5 1/2 wide. It's more common to see the 16 inch artillery wheels on earlier trucks. 16 inch artillery wheels were standard equipment on 1936 GMC 1/2 ton and may have been an option for Chevy.
#245869 10/23/2006 3:33 PM
Thanks for the info. Sounds like the 16 inchers are not as good as the 15ers have more options. Are they available for a reasonable sum or very hard to come by? Thanks in advance, Patrick
#245870 11/18/2006 11:48 PM
Apprentice
Apprentice
The price continues to go up on the artillery wheels particularly the 15 inch. This is one of the best sets I've seen on Ebay.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=011&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=320047614905&rd=1,1
#245871 11/19/2006 3:39 AM
i think coker tire has a radial 6.00-16 wide white wall. 1-800-251-6336
tom
I don't suffer from insanity, I enjoy every minute of it!
