5 members (2-Ton, Jimmie D, klhansen, Hanks custodian, 1 invisible), 109 guests, and 2 robots.
Topics128,167
Posts1,057,015
Members48,458
Hi,
I have a '61 and want to switch from the sliding rear windows to the fixed style. All 4 windows, if possible.
Anyone know what's required? Anyone want to swap their fixed for set of sliding? I have all 4 rebuild kits, new rubber, felt, etc.
Thanks, Chris
925-708-5295
I don't know what's involved in the swap, but if you want to sell two of the rebuild kits, I'd be interested.
That doesn't really help you out with your question though...I would bet a factory assembly manual would answer the question. I don't have one, but they're listed on ebay all the time. I need to get one myself!
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
I would buy the other two(my burb only has two sliders),,you can have the flat glass cut at any decent glass shop out of laminate,shouldn't cost too much,the weatherstrip is a common variety,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I just removed the a pair of one piece fixed windows and it was held in with just the rubber gasket. Like mentioned above, any glass shop can cut the glass. It's the gasket that they may not have. Best to check with the specialty vendors for the gasket.
BTW I have a pair of sliders available but no locks.
Junior Member
Junior Member
2 Offline
Don't mean to jump on this post, but I just acquired a '61, which has 4 sliders in the back. I am in need of all 4 window locks, if you are able to convert to one piece glass I'd be very interested in your old stuff.
