5 members (1955 1 Series, Gdads51, KEVINSKI, 2 invisible), 96 guests, and 2 robots.
Topics128,170
Posts1,057,033
Members48,458
When the engine fellow reinstalled the head gasket on my rebuilt 261, I noticed the #1 and #6 pistons were at the top of their strokes (besides being new and very, very pretty).
How can I tell if #1 is at TDC or 180 degrees off after I install the lifters, pushrods and rocker arm assembly?
I know you can feel for pressure in #1 spark plug hole while turning it over but is there a way to figure it out by just looking at the pushrod or valve positions?
Thanks!
At TDC the #1 cylinder will have both valves completely closed. If you've got it 180 degrees off, the exhaust valve should be just closing.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
This is something I have also wondered. If in this case the distributor rotor points at plugwire #1 and the flywheel ball is in the window. Does that mean it is in the proper #1 firing position?
In other words, with the ditributor pointing, and the flywheel ball in the hole, can the motor be 180 degrees off? Or do these mean it is always right?
54 3100 with 235
62 flatbed dump C60 with 261
Yes the distributer can still be 180deg out, the easiest way is to take #1 plug out and turn the engine over by hand till pressure is felt, continue turning till the tdc ball shows up, then install the distributer pointing to the #1 sparkplud lead.
If your engine has been running without the distributor being disturbed, Yes you can take the cap off, see the rotor pointing at # 1, see the ball in the flywheel hole and know for certain that you are at TDC # 1 firing position..
If the distributor has been removed, all bets are off.. I usually spin the motor by hand watching the second valve back from the front. When the valve rises up ( # 1 intake closing ) keep spinning until you see the ball line up with the pointer, now you are at # 1 TDC. Drop your distributor in with the rotor pointing towards the # 1 wire position on the cap..You may have to adjust the timing, (move the distributor a little left or right) to get the engine to start..Works every time..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
These folks have it, valves fully closed, you can tell because there will be a little lash in the rockers(if the engines cold, and it doesnt have hydraulic lifters), and the timing mark dead on. If it does have hyd. lifters, the same procedure is used, but you wont have any lash.
JKU72
56 3100
68 Suburban
That is what I wanted to know for, to adjust valves.
54 3100 with 235
