| | | Forums66 Topics128,165 Posts1,057,087 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | Hi guys,this is my 1st post. I have someone who wants to give me a linkpin set that goes to a 55 olds 88. Will they fit my 52 Chevy panel truck? Any input would be welcome,thanks! Jeff | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hey Jeff, welcome to the forums - what's a 'linkpin'? if you mean king pins , not likely - Carter has\'em , but the cars and trucks are different steering and suspension got a pic of your truck online? we love pics here, and can never see enough panels!  you're encouraged to send a short writeup and some pics to the editor for the gallery too Bill | | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | Originally posted by red58: hey Jeff, welcome to the forums - what's a 'linkpin'? if you mean king pins , not likely - Carter has\'em , but the cars and trucks are different steering and suspension
Bill KINGPIN! Thats what I meant! OK so you dont think the 55 olds ones would work huh? I will post some truck pics. when I tack some soon. Its an old green Railway Express Truck. Runs just fine. thanks for the info. Jeff | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hey now that's a gas!! we gotta get that in the gallery fer sure - and keep us posted on yer progress no the olds will be way different - the REA trucks were prolly 3/4 even, maybe 1 ton Bill | | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | Thanks Red! No its not a 1 ton. Its a 1/2 ton 3100 Thriftmaster type. I think the engine is a 1962. Its still a 6 cyl. stovebolt type. i think its bigger than the orig. Has a 12v.system now w/turn signals. Although the guages all blew out [save the bat.gage] I guess cuz they were the 6v. ones. Jeff | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The stock guages are all mechanical except the amp guage and the gas guage. If your oil pressure and water temp guages don't work its not likely the problem is directly related to the 12 volt conversion.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | Originally posted by OldSub: The stock guages are all mechanical except the amp guage and the gas guage. If your oil pressure and water temp guages don't work its not likely the problem is directly related to the 12 volt conversion. Oh,OK. Do you have any Ideas what the problem might be? Any input would help. Thanks Jeff | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well describe the symptoms... Do they simply do nothing?
First I'd check to make sure the tubes are intact and connected, and have no kinks.
