| | | Forums66 Topics128,265 Posts1,058,364 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | o.k. i dida search and came up empty. so what's the trick to removal of the lock and latch? i have the handle removed but the lock pin is still in the latch mechinism. there is no key to the lock,thanks for any help .tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | TPYLE,
My description will not be clear - sorry - but I will try.
[this post has been corrected, after I looked at my spare latch/lock/door)
Look at the edge of the door on the latch side (not the hinge side). You will see the end of a piece of metal plate that is inserted/slid into the door to hold the lock mechansim in place. Use a lot of penetrating oil because the plate will be rusted and hard to slide out.
After you slide this retainer plate out, the lock mechanism will come out. Then you can get the latch out.
I have a spare lock/latch mechanism in a spare door and will post a few photos this evening.
Tim | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | that will be cool as a pic is worth a thousand words. hopefully ,it will spare the cuss words.  thanks tom
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Tom, The lock plate is circled in yellow in this photo. I recall that I used a stiff putty knife to pry under the lip/edge of the lock plate (after applying a lot of penetrating oil). It looks like someone used a small screwdriver on this plate. Tim | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | hey tim can't get to that pic says it forbidden
Try it again and let me know what you get. The OS on the server was being upgraded yesterday evening.
Tim | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | That picture works fine for me now. That little clip really amazed me when it came out of my rusty old door, a few years ago, as per the manual. | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | well loookie there!if it was a snake it woulda bit me.thanks tim,--- truckernix which manual are you refering to,i didn't see anything like that in my shop manual. it goes into pretty good depth on the burb clamshell though.
