2 members (homer52, Tronman), 113 guests, and 5 robots.
Topics128,077
Posts1,056,033
Members48,433
#245278 02/10/2006 3:53 AM
Has anyone installed speaker kick panels in their trucks? I am looking at adding front speakers and saw GMC Pauls and Jim Carter sell kick panels. What are your thoughts? My original dash has been cut so I cant put a stock radio and dual voice coil speaker up front. I guess I can but dont want to re weld the opening.
Mac
#245279 02/10/2006 5:39 AM
V
V Offline
The speakers are usually too low for good sound in that location. If you just want some sound and aren't picky about how clear the sound is, they are fine. I think Rod Doors has a kickpanel setup also.
You would probably be better off with a behind-the-seat all in one triangular speaker box, with a single woofer and upward firing tweeters (usually a horn of some kind) - as long as the gas tank is out of the cab. You can place some small dome tweeters on the dash to fill out the high ranges.
#245280 02/10/2006 2:20 PM
The worst place to install speakers is facing each other.
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
