| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 153 | Has anyone installed speaker kick panels in their trucks? I am looking at adding front speakers and saw GMC Pauls and Jim Carter sell kick panels. What are your thoughts? My original dash has been cut so I cant put a stock radio and dual voice coil speaker up front. I guess I can but dont want to re weld the opening.
Mac | | | | | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | The speakers are usually too low for good sound in that location. If you just want some sound and aren't picky about how clear the sound is, they are fine. I think Rod Doors has a kickpanel setup also.
You would probably be better off with a behind-the-seat all in one triangular speaker box, with a single woofer and upward firing tweeters (usually a horn of some kind) - as long as the gas tank is out of the cab. You can place some small dome tweeters on the dash to fill out the high ranges. | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | The worst place to install speakers is facing each other. | | |
