0 members (), 79 guests, and 1 robot.
Topics128,195
Posts1,057,374
Members48,469
#245268 02/09/2006 3:47 AM
Yet another dumb question. My 49 sub has the fresh air cowl vent on the left side and the vent on the top of the cowl just behind the hood. Both of these vents have handles for opening and closing. Directly opposite of the left side cowl vent is a louvered vent that seemingly has no purpose. While replacing the right side inner cowl panel I noticed that the louvers lead into a closed area between the door post and the front fender. There is also a removable cover on the inside of the cowl panel that seals the area off. I am trying to figure out what the louvered area is for. Any help out there? Weeds
#245269 02/09/2006 4:03 AM
The vent on the right hand side (passanger) is for air circulation for a heater setup. To install the heater, the cover which acts as a blank plate, needs to be removed.
#245270 02/09/2006 4:22 AM
Just to be more specific, this is called the fresh air heater because it draws it's air from outside through those louvers. The other knd of heater does not attach there and recirculates air from inside the cab through the heater core.
1951 1 Ton Completed
#245271 02/09/2006 6:13 AM
#245272 02/09/2006 2:46 PM
Very cool. No pun intended.
Doyou have a lot of old literature?
MV
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
#245273 02/10/2006 4:43 AM
si47, Tnix and Mike Vee thanks for educating me. And MT the picture says it all. Weeds
#245274 02/10/2006 5:03 AM
Nah, MT doesn't have a lot of old literature...or any trucks, for that matter. :p
1954 GMC De Luxe COE
#245275 02/11/2006 3:28 AM
Staying somewhat on topic, does any one know where to get a cover plate for the fresh air heater opening? Nobody seems to reproduce those.
1954 Chevy 3100 Panel Truck
2004 GMC Yukon
2002 Chevy 1500 4X4
"Those who expect to reap the blessings of freedom, must, like men, undergo the fatigues of supporting it."
Thomas Paine, The American Crisis, No. 4, September 11, 1777
#245276 02/11/2006 11:16 PM
MT. Carter's has access to used parts, they probably have some. Heck, I might have a decent one around here.
#245277 02/19/2006 9:18 AM
I have seen the cover plates on ebay or try the swap meet on hear
