1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 25 | New guy question here. Is the frame/ suspension on a 60-66 GMC suburban is the same as a Chevy of the same years? Thanks, Kael | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Don't think everyone's ignoring you. My guess is nobody knows. I know they are different in the '47-'55 first series run but don't know about your series. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I don't know...
The '47 to '55 1st frames differ because the motors are different and mount a little different. With side mounted motors that should not be an issue.
Look at the rear suspension on any frame you are considering and check to see that it is the same as on your truck. If I remember correctly either might have leafs or coils, though Chevy is usually coil and GMC usually leaf.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2005 Posts: 46 Member | | Member Joined: Jul 2005 Posts: 46 | the 60-66 frames are different. the GMCs have leaf spring suspention and the chevys had coil spring. but besides that they are the same. the 60-62 gmc frames do have the coil springs too.
63 4X4 GMC Suburban FOR SALE 1951 chevy sedan delivery !FOR SALE!
| | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | '60-'62 front end are torsion bars, later models area 'A' frames. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | GMC had rear leafs as standard. Coils were an option Chevrolet had rear coils standard. Leafs were an option. Old Sub's statement is correct. Either truck could have either suspension. Although leafs may have been a requirement for a Suburban no matter which brand. So I guess the short answer to your question is, "Yes".  | | | | | Joined: Jan 2002 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 25 | Thanks for the answers. I guess that I should have been more clear (even though I ultimately got the answer that I was looking for), I mainly wanted to know front suspension and engine/transmission mounting similarities.
Leafs vs. coils for the rear is not a big issue although I think I like the coils better. Until last month, I used a 60 Chevy 3/4 ton as my personal workhorse. One of the trailing arms finally broke which just sped up its retirement. Otherwise the body would have fallen off soon. I also drive a 2001 Dodge 3/4 as my company vehicle. I carry about 800 lbs of equipment in this truck at all times. I felt that the Chevy was a more comfortable ride whether it was empty or loaded with almost 1.5 tons of scrap. Anything over 1 ton in the Chevy did cause the steering to feel light, but that should be expected. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Originally posted by k10: GMC had rear leafs as standard. Coils were an option
My '62 Suburban has coils in the rear, with T-bar front suspension. -Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | |
