3 members (Woodcmiami, Bill Hanlon, 2-Ton), 108 guests, and 2 robots.
Topics128,109
Posts1,056,258
Members48,437
#24518 08/13/2003 4:26 PM
I believe that there is a front mount for the cab just in front of the radiator but dont know what it is suppose to look like. If anyone can show me a picture I would be grateful. Thanks, Greg
1951 1.5 ton 4400
I'm a bit confused. Are you talking about a cab mount for a COE, or the radiator support mount, which is a strip of thick rubber under the center of the radiator support?
Fred
52 3600
69 C-10
Thanks Fred.
The front of the cab will bounce higher than the frame then come down and hit the crossmember in the front when I hit a bump in the road and there is a lot of them per mile.
Greg
1951 1.5 ton 4400
Sounds like you need to replace the cab mounts, there are four of the, all under the cab. The front ones are a rubber pad with a bolt through floor, just inside the front of the doors. The rears are a shackle arrangement, near the back at the frame.
Sounds like you don't have a shop manual, well worth the $25 investment, and describes all of this.
Fred
52 3600
69 C-10
You are right Fred I dont have a manual.
Thanks for the information.
I will look at the front ones and see if there are any rubber left.
greg
1951 1.5 ton 4400
#24523 08/13/2003 11:18 PM
The front ones also tend to rust out, so that could be a problem too.
Paint & Body Shop moderator
#24524 08/14/2003 12:36 AM
Thanks Josiah. I just cant believe the front end sticks out to the front bumper without any suppport. I just need to know what it looks like so I can make another one.
Greg
1951 1.5 ton 4400
It looks like a piece of machinery belt, only softer. I'm thinking about 1/4 or 3/8" thick, but not real sure. There are two styles, one piece is before 50, two piece is 50 & later. However, my 52 has the early style.
[img]http://www.americanclassic.com/images/RDR-23.gif[/img]
[img]http://www.americanclassic.com/images/RDR-26.gif[/img]
Fred
52 3600
69 C-10
Greg,
All coventional ADs had a front mounting under the radiator cradle....if the rubber's gone, she'll bang like hell !
I had to do this as a "budget repair" on my '54 when I was in high school and used a layer or two of tire carcass.
I think the bolts that go through the radiator support and into the frame are carriage bolts, and mine kept spinning as I tried to remove the nuts...I think I jammed a fat cold chisel against the head to keep 'em still enough to remove the nuts.
Good Luck!
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
Thanks Frank and Fred, I have a block of 3/4" plywood in there now and will change it out for a piece of conveyer belt I have. That block of wood made a big difference.
Greg
1951 1.5 ton 4400
