1 members (JW51),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24518 08/13/2003 4:26 PM | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | I believe that there is a front mount for the cab just in front of the radiator but dont know what it is suppose to look like. If anyone can show me a picture I would be grateful. Thanks, Greg
1951 1.5 ton 4400 | | |
#24519 08/13/2003 6:34 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I'm a bit confused. Are you talking about a cab mount for a COE, or the radiator support mount, which is a strip of thick rubber under the center of the radiator support?
Fred 52 3600 69 C-10
#24520 08/13/2003 6:45 PM | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | Thanks Fred. The front of the cab will bounce higher than the frame then come down and hit the crossmember in the front when I hit a bump in the road and there is a lot of them per mile. Greg
#24521 08/13/2003 8:43 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Sounds like you need to replace the cab mounts, there are four of the, all under the cab. The front ones are a rubber pad with a bolt through floor, just inside the front of the doors. The rears are a shackle arrangement, near the back at the frame.
Sounds like you don't have a shop manual, well worth the $25 investment, and describes all of this.
#24522 08/13/2003 8:50 PM | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | You are right Fred I dont have a manual. Thanks for the information. I will look at the front ones and see if there are any rubber left. greg
#24523 08/13/2003 11:18 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The front ones also tend to rust out, so that could be a problem too.
#24524 08/14/2003 12:36 AM | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | Thanks Josiah. I just cant believe the front end sticks out to the front bumper without any suppport. I just need to know what it looks like so I can make another one. Greg
#24526 08/14/2003 6:54 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Greg,
All coventional ADs had a front mounting under the radiator cradle....if the rubber's gone, she'll bang like hell !
I had to do this as a "budget repair" on my '54 when I was in high school and used a layer or two of tire carcass.
I think the bolts that go through the radiator support and into the frame are carriage bolts, and mine kept spinning as I tried to remove the nuts...I think I jammed a fat cold chisel against the head to keep 'em still enough to remove the nuts.
Good Luck!
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#24527 08/15/2003 3:12 AM | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | Thanks Frank and Fred, I have a block of 3/4" plywood in there now and will change it out for a piece of conveyer belt I have. That block of wood made a big difference. Greg
