0 members (),
44
Mod | | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 11 Junior Member | | Junior Member Joined: Oct 2004 Posts: 11 | Haven't had time to pick up the appropriate shop manual yet but can someone get me some specs for a '54 235. I need timing info, point gap and/or dwell, idle rpms. Got spark plug gap and valve clearance. She's been "asleep" for 10 years but is going to "wake up" this week. I'm in MN, a block heater a good idea? Thanks. Mark | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mark,
This information if the the 1954 Truck Shop Manual, page 6-18 . .
Plug gap: .035 (20-25 lbs torque with new "gasket") Point gap: .016" (.019" new points)
Set idling speed to 450-500 rpm Set mixture screw to highest vacuum reading (should be between 17-21 inches) Reset idle screw, if necessary
Ignition timing (cam angle/dwell 38-45 degrees with .016 point gap): - set octane selector to zero (middle mark) - timing light connected t0 #1 plug lead - run at idle (no instructions to disconnect the vacuum line) - loosen clamp screw on distributor (on the vacuum advance, behind the distributor). - rotate distributor until steel ball on flywheel lines up with the pointer on the flywheel housing. - tighten clamp screw on distributor.
If idle speed changes significantly, redo carb speed/mixture and then redo timing.
Make sure manifold heat (riser) valve is moving freely (and has a god spring)
Tim | | |
#2450 01/03/2005 10:58 PM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Are those specs the same for a 62, 235?
Thanks, Tom
delete my account and pictures
