2 members (55shaker, Jon G),
79
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Which do you prefer and why?? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I agree with Joe; but, the end-gate (clam shell) door is a conversation piece. | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Well how about this! Im looking for a burb and i would prefer a clam shell, but a barn door would do too. Why not have both? Just take a burb or panel with barn doors and cut just below the glass, weld the top 2 pieces to make a 1 piece and make the glass a 1 piece also. make it so it flips up just like a clam shell. Then you have the lower doors to swing out, like their supposed to. And Wa-la! A Barn Shell! | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I noticed an oddity on my '52 Burb...the diamond shape metal covers (with hole in the middle) on the outside rear door frames are from a clamshell rear set (cable guides) up ...but I have a barn door truck. Were all AD Burbs setup to be either? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | all panel bodies of any year are setup to accept either door option
Bill | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | It depends on how you are going to use your suburban. If you plan on going in and out of the back with large objects...barn doors. If you plan to have seats in the back and only put small items such as picnic baskets, tool box etc....clamshell tailgate. I like the look of the clamshell tailgate and the lift gate window for better viewing, ventilation (caution if you have your tail pipe coming out the rear) I like the clamshell tail light too. To answer you other question on if you can mount either style doors, a simple answer is yes....but there is some problems if your Suburban came with a clamshell and you want to convert to barn doors. There is no reinforcement for the door checks. The problem with converting from barn doors to clamshell is there is no support for the lower hinges (important) and you will have to find tailgate retractors and cables as well as other pieces to complete the conversion. You will have to cut the lower body panel to allow the hinges to go through too. You can purchase the body plugs from several vendors to close off the barn door hinge holes.  ......g | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I prefer the barn doors though I like the clam shell window. I'd like to have a tailgate to use on one of my projects, and I keep thinking it will appear one of these days...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2005 Posts: 29 Junior Member | | Junior Member Joined: Sep 2005 Posts: 29 | I'll agree with Joe also. I used my burb for camping alot and the barn doors make it easier to get in and out. I have a newer Blazer with the tail gate and it is a reach to unload stuff from the back. JMHO
Jim | | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | Looks - Clam Shell Function - Barn Doors
A few years back someone here was going to build barn door bottoms with calm shell top, did it get done? I never heard anymore about it but I think that would be the best!!!
Hmmmm...Another Project...You need to work on that TM2c
Buddy in AK | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | TooMany, that would be a "best of both worlds" kind of thing...if anyone has ever done it, I want to see pictures. That said, my Panel is a deluxe with the stainless trim around the barn door windows, so I guess the barn doors get to stay unmolested. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I always thought that hatch over doors approach seeming odd on Astro vans. I never owned one and have no experience with them.
My '55 1st has the stainless around the barn door windows.
I've got a better set of doors that don't have the stainless, and I've been wondering how to move the trim from one set to the other.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Steve,
We moved the Suburban rear-window trim to a non-trim door by making a template from the trimmed door and using the template to drill and form holes on the non-trim door.
Restoration Specialties sells an exact replacement clip for attaching the stainlees strips to the doors. I sent them one of my old ones.
Tim | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Thanks Tim! That's information I'll use!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2005 Posts: 46 Member | | Member Joined: Jul 2005 Posts: 46 | Originally posted by beast54: Well how about this! Im looking for a burb and i would prefer a clam shell, but a barn door would do too. Why not have both? Just take a burb or panel with barn doors and cut just below the glass, weld the top 2 pieces to make a 1 piece and make the glass a 1 piece also. make it so it flips up just like a clam shell. Then you have the lower doors to swing out, like their supposed to. And Wa-la! A Barn Shell! i would like to see that
63 4X4 GMC Suburban FOR SALE 1951 chevy sedan delivery !FOR SALE!
| | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | When i get my hands on a burb with barn doors, im going to do that! Anyone have one they want to sell? | | | | | Joined: Jul 2005 Posts: 46 Member | | Member Joined: Jul 2005 Posts: 46 | what year burb are you looking for?
| | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Im looking for a 47-55 chevy/GMC burb, but i will consider any, nothing newer than 55 2nd series. Thanks | | | | | Joined: Jul 2005 Posts: 46 Member | | Member Joined: Jul 2005 Posts: 46 | oh ok well if you want a 60-66 suburban that rj has a few for sale?
