6 members (Nick in Manitou, TooMany2count, wilbur53, walter74, 2 invisible), 74 guests, and 0 robots.
Topics128,076
Posts1,055,920
Members48,429
#244790 11/02/2005 8:26 AM
The engine I want to install in my 59 suburban is the 5.3 Chevy that frequents the Silverado and Trailblazer.
What are some of the difficulites I will face with using this computer laden setup. Obviously I will have to figure out a way to get a return fuel line to the gas tank with the electronic pump. I'm sure there are many other unseen problems that I will run into.
Any input would be appreciated.
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
#244791 11/02/2005 9:14 PM
this is a cool preject and if i am not mistaken one of the 4x4 magazines did this not too long ago. they put a 6.0 litre v-8 in a k-5. it turned out really coo, and those engines are smooooooth, smooth revs, power and etc. go for it.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#244792 11/03/2005 5:15 AM
Moderator
Moderator
Do you have to modify the tank for a return line? What's to stop you from just T-ing the return into the fuel line between the tank and pump?
I was thinking that you would need to verify that there is no sock inside the tank to blow off with back pressure, but the return pressure should never be more than the pump is drawing.
Another thought is to get your engine from a parts truck and get the tank, electronics, wiring harness and everything else you can think of.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#244793 11/03/2005 6:45 AM
I'm probably getting the engine from a salvage yard and I'm sure I could get the tank as well. Would it fit?
More on Hotrodders
#244794 11/03/2005 6:54 PM
Garret I put an 83 El Camino tank behind the axle of my 49 Burb. It has the return line which I have capped for now. Get the tank straps from the donor vehicle and it is an easy fab job. You also need to thnk about where the filler neck will be located. Good Luck
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
#244795 11/03/2005 7:21 PM
Moderator
Moderator
Quote
Originally posted by garretthes:
Would it fit?
Only you and your tape measure know for sure...
Quote
I went to an exhaust shop and they custom bent a filler tube for a very reasonable price. That fuel grade hose you have to buy to join it is expensive compared to the cost of the steel tubing. And don't forget to throw some paint on it. Can't be having it rust out...
Burma-Shave (1947)
