6 members (BC59, gswbbc, Hanks custodian, 55shaker, dt235sd, wilbur53), 70 guests, and 1 robot.
Topics128,048
Posts1,055,538
Members48,424
#24468 11/13/2003 9:33 PM
ove
Offline
Apprentice
Apprentice
I am restoring a 59 3100 apache and have a 350 big block oldsmobile engine I am planning to fit.
Does anyone know if this is posible. I am thinking about the widt of the engine compared to a sb 350.
I'm sure its possible, that engine compartment is pretty big...
I've seen Buick and Cadillac motors in Chevy pickups, but don't know much about the Olds.
#24470 11/13/2003 10:09 PM
hello ove. i once put an olds 455 into a 67 gmc. as i remember the front mount bractets on the frame had to be moved forward, the motor was bolted to the chevy bell housing using a tci adapter plate, the headers were for a mid size olds car,and i used a saginaw 4 spd. it fit good, it sounded real good, but that long stroke engine wasn't very good for everyday use with the low gearing the rear axle had. good luck
our garage is a non-profit organization
#24471 11/13/2003 11:46 PM
k10 Offline
I have what I was told was a 350 Olds motor sitting in a parts truck of mine. What to look for ? Can any one post a pic and is the motor worth doing anything with or just sell it for scrap?
#24472 11/14/2003 12:27 AM
http://glorene.com/auto/main/gallery/1968_1969/FrameSet.htm
scroll down to the pic of the engine.
This is a pic of a typical olds engine. Oil filler on front of intake is the big giveaway. Most were painted gold, had rochester 2bbls or Q-jet 4bbls, rear distributor, strange looking timing cover. Low RPM torque monster, similar in performance to pontiac 350 but no parts interchange. Don't revv them past 5 grand with stock cast rods. Good motors. More expensive to rebuild than SBC, but good power potential. 2bbl 9:1 compression motor was rated at 250 HP stock.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
k10 Offline
I'm pretty sure mine doesn't look like that. If you know what I mean. wink
I'll have to go take another gander at it before it's locked in for another winter. eek
