3 members (hardshell, FishinToms53, lumbersawyer), 45 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#244522 08/13/2005 4:29 AM
Junior Member
Junior Member
I have a 49 panel delivery that has the front window track broken loose at the bottum. Is this spotwelded in that I have to cut the door to make room to weld it back in? Does any body make a replacement that could be possibly bolted in? The catalogs that I have do not show anything for the no vent window. Any help would me apprecdiated. Thanks Al
#244524 08/14/2005 9:55 AM
Hmm...I know it was bolted at the bottom on the '51-up models with the vent windows. You might want to get a mirror and look up in there, it could be as simple as a missing bolt. The doors are the same as the pickups and other trucks, you might get more answers if you ask in one of the other forums.
1954 GMC De Luxe COE
#244525 08/14/2005 11:13 PM
Junior Member
Junior Member
Mine did the same thing and I used a SS sheet metal screw slightly larger to catch it and it drew it in perfectly. I also had everything out of the door and the kick panel removed so it was a little easier.
