Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Ed Atkisson, TUTS 59), 46 guests, and 5 robots.
Topics128,010
Posts1,055,299
Members48,419
#24443 02/12/2004 1:38 AM
Junior Member
Junior Member
The 2.8 in my donor is extremely hard to start cold. New battery, fuel pressure regulator & control module (none for this problem). anybody know what sensor would cause this problem. The manual is a great help, it says choke inoperative. I realize the choke is inoperative since it has TBI and no choke.
There is no mechanical problem so difficult that it can not be overcome by brute force and ignorance.
#24444 02/12/2004 2:24 AM
Junior Member
Junior Member
I had problems with my 85 2.8 S-10 starting cold.
It was the coil. It would get real dirty from time to time, from being run on a rural mail route with miles of dirt roads. When this hapeened it would short out and spark to ground through the dirt. I would clean it off with some soap and water or gas in a pinch. Than thouroly dry it off and I would coat it with polyurethane. Than it was good to go for another year or so.
Don't know if this helps or not.
#24445 02/12/2004 2:27 AM
I'am assuming this 2.8 is the multiport fuel injected, have you run the diagnostic on the computer to see if there is any errors stored, but it could be the coolent temp. sensor, not sensing a cold engine giving enought gas on a cold start.
#24446 02/12/2004 7:06 AM
Check the timing too, and replace the plug wires with new ones. You need a healthy spark to light the cold, rich mixture.
Paint & Body Shop moderator
#24447 02/12/2004 7:55 AM
99% chance it is coolent temp. sensor
#24448 02/12/2004 12:54 PM
I have to go with the coolant temp sensor. Had a 88 Celebrity (high mileage). When it was 15 - 25 degrees and relatively high humidity and having sat out all night the car would have to be cranked for over a minute -- many false starts and backfires -- once started it ran fine. I just carried a wrench and an extra sensor as I was on the road 5 - 6 days a week and being late for an appointment was wasn't an option. Less than 5 minutes work and I was on the road again.
#24449 02/18/2004 12:41 AM
Junior Member
Junior Member
Coolant sensor fixed it thanks.
