1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 40 | I just rebuilt the left hand rear door latch assembly on my 58 panel. Does anyone have a drawing or a picture of what the top latch looks like? I ended up fabricating new springs and new blocks for the middle assembly. But I need an idea of what the top latch looks like, mine's gone. If you could send me some dimensions, I'll make some extras if any body else needs them. Thanks.
Mike
In loving Honor of PFC Benjamin Gandalf Young 30 March 1988 - 27 May 2007 Sometime I wonder, Who you'd be today www.BENS58.COM | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | I could take some pictures if you can be more specific. | | | | | Joined: Apr 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 40 | It's the upper latch that bolts to the door frame that I'm missing. There is a lower latch that bolts to the lower door frame that I have that looks like it's cast iron, but I'm missing the upper latch. The two hooks that are at the top and bottom of the door hook into these latches. If the upper latch is the same as the bottom one, then I could machine one using the bottom one as a pattern. Thanks for your help.
Mike
