0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#244306 01/06/2005 4:37 AM
If I'm ever going to drive this thing down the road, I'm going to need to do something about that plastic tubing spliced into my fuel line and the lawn-mower can bungeed to the passenger seat.
So. Tomorrow I'm planning on dropping the tank to get the crud out. Any tips. Anything you wish someone had told you before YOU did the same thing? Beyond a good solid scrubbing what else should I do to the tank while I have it off?
Thanks in advance.
-Joel
'52 3800 Panel
School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind.
inside of a dog it's too dark to read.
-Groucho Marx
#244307 01/06/2005 10:19 PM
definitely have it sealed if there is any rust in it. what kind of a "thing " are you talking about? mine was a 46 suburban and it was pretty bad. it came back as something i don't have to worry about. worth alot to me.
jim
#244308 01/07/2005 4:28 AM
First thing to do is to pull the fuel guage sender unit from the top of the tank. You can then look into the tank and get an idea of the condition.
Worst case of course it a totally corroded interior which could mean a tank replacement. You can get the tank 'boiled out' I understand. Perhaps radiator shops offer this service.
If the tank can be cleaned out reasonably well, but still has surface defects (coating off in places) - then coating is an option.
My origional tank was trash when I pulled it. The tank I got from my parts car looked really good. I just gave it a good pressure wash, and when dry - gave it a treatment with dilute phosphoric acid just in case. I'd recommend the acid treatment before coating if that's the route you go.
Good Luck!
