4 members (55shaker, Forty9, Jon G, BillCollins), 203 guests, and 7 robots.
Topics128,080
Posts1,055,956
Members48,430
I've tried to buy these gaskets from Chev's of 40's but the're out of stock and don't know when they'll get more...anybody else sell these things?
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
Not sure about these in particular, but i've made mounting gaskets for several odd ball things from an inner tube. Need to be careful trimming so it doesn't look hacked though.
40 Chevy 1/2 ton
Did you try Steele?
1954 GMC De Luxe COE
I cannot remember the appearance of the gasket that came in the NOS package; but, either the NOS gaskets or the Chev's of the 40's gaskets (I had a set of each) were simply a flat piece of rubber (shaped to the flat mounting edge of the bullet). One set of gasskets had a lip that sealed agaisnt the bullet.
DennisM's suggestion is a good one (I have used sheet rubber and inner tube rubber).
I do not see the gaskets listed in the Steele catalog (but I might have looked in the wrong place).
Tim
Look for '39 Chevy taillight gaskets. I think this is it: 60-0122-15.
A few months back, I was cruising around on ebay and found a guy that had some for sale. Shoulda saved his name but didn't. You might check there. They were around 6 bucks.
1954 Chevy 3100 Panel Truck
2004 GMC Yukon
2002 Chevy 1500 4X4
"Those who expect to reap the blessings of freedom, must, like men, undergo the fatigues of supporting it."
Thomas Paine, The American Crisis, No. 4, September 11, 1777
Moderator
Moderator
I have made gaskets by using RTV silicone. Just make sure you coat any surface you don't want it adhering to with vaseline. (Maybe another use for WD-40 also.) Wipe the vaseline off so it's only a thin coating. Make sure you have your part shimmed properly to achieve the thickness you want. Goob it up with the silicone and mount it. (You can use a finger to go around the bead and smooth it, or just wait to trim it later. I usally smooth the bead and trim the little excess that squeezes past my finger later.) Go out there the next day, disassemble it and trim the gasket as needed. An X-Acto knife works really well. For larger areas you may have to wait up to a week to allow adequate cure time. The RTV is usually available in a number of colors too.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
