9 members (cmayna, TUTS 59, Hanks custodian, Otto Skorzeny, Oswald, Cosmo, Bill Hanlon, gswbbc, oldsteve),
71
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24412 11/20/2004 9:09 PM | Joined: Oct 2003 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 66 | I have a '50 3100. A previous owner modified it by installing an open Hotchkiss driveline, and a modern 235 engine.
My problem is that I need a pair of e-brake levers for my truck, and I can not figure out exactly what year model rear axle he put in. Therefore, I don't know what year model e-brake levers to ask for. Perhaps one of you can ID it for me?
It appears to be a GM Corporate 8.5. It has six lug wheel flanges. It has self adjusting drum brakes. It has no brake adjusting slots cut in the back plates. It has "GM8" embossed on the lower left front of the pumpkin. It has "C235" embossed on the lower right rear of the pumpkin.
I have scrapped and searched all around both of the rear axle tubes, in hopes of finding a stamped code. So far, no luck.
It had leaking wheel cylinders. I just replaced them with 1955-1972 Federal Mongoul wheel cylinders. They were an exact match, and a perfect fit for the old leaky cylinders.
I am thinking, and I could be all wet, that based upon the last number in that "C235" code, that I am dealing with a 1955, 1965, 1975, or 1985 rear axle.
Does anyone have a clue what year self adjusting brakes first appeared on Chevy trucks? What year did rear drum brakes go away? Can anyone ID this axle based upon the information I have provided? | | |
#24413 11/20/2004 10:23 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | A picture of the rear cover would help. That is usually the fastest way to narrow down what a rear is from...
Modern 235? They quit making those in 1962.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#24414 11/20/2004 10:48 PM | Joined: Oct 2003 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 66 | Come on now OldSub, you young whippersnappers should know that the word "Modern" is a totally relative term! Why 1962 was just last week or so! Wasn't it? :-)
I forgot to mention in the original post that it is a ten bolt rear. I'll post a picture soon. | | |
#24415 11/21/2004 12:18 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Sounds like a 80s 4x4 rear axle...Brian | | |
