3 members (WICruiser, Charles in CA, Otto Skorzeny), 37 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#24412 11/20/2004 9:09 PM
I have a '50 3100. A previous owner modified it by installing an open Hotchkiss driveline, and a modern 235 engine.
My problem is that I need a pair of e-brake levers for my truck, and I can not figure out exactly what year model rear axle he put in. Therefore, I don't know what year model e-brake levers to ask for. Perhaps one of you can ID it for me?
It appears to be a GM Corporate 8.5. It has six lug wheel flanges. It has self adjusting drum brakes. It has no brake adjusting slots cut in the back plates. It has "GM8" embossed on the lower left front of the pumpkin. It has "C235" embossed on the lower right rear of the pumpkin.
I have scrapped and searched all around both of the rear axle tubes, in hopes of finding a stamped code. So far, no luck.
It had leaking wheel cylinders. I just replaced them with 1955-1972 Federal Mongoul wheel cylinders. They were an exact match, and a perfect fit for the old leaky cylinders.
I am thinking, and I could be all wet, that based upon the last number in that "C235" code, that I am dealing with a 1955, 1965, 1975, or 1985 rear axle.
Does anyone have a clue what year self adjusting brakes first appeared on Chevy trucks? What year did rear drum brakes go away? Can anyone ID this axle based upon the information I have provided?
#24413 11/20/2004 10:23 PM
A picture of the rear cover would help. That is usually the fastest way to narrow down what a rear is from...
Modern 235? They quit making those in 1962.
#24414 11/20/2004 10:48 PM
Come on now OldSub, you young whippersnappers should know that the word "Modern" is a totally relative term! Why 1962 was just last week or so! Wasn't it? :-)
I forgot to mention in the original post that it is a ten bolt rear. I'll post a picture soon.
#24415 11/21/2004 12:18 AM
Sounds like a 80s 4x4 rear axle...Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
