2 members (J Lucas, JW51), 266 guests, and 1 robot.
Topics128,081
Posts1,056,074
Members48,434
#244002 03/21/2005 1:21 AM
Looks like I HAVE to replace my oil pan gasket now. There is a huge crack in the pan just above the drain plug. Anyone near Nashville have a pan for sale? It's a 235 (1959)
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
#244003 03/21/2005 2:35 AM
I dont have a pan but it will probably be weldable.
I like old trucks
#244005 03/21/2005 3:28 AM
Cooooool! I hate buying parts for an engine I don't want to keep. I will fix it with my friensd trusty wire feed welder.
More on Hotrodders
#244006 03/21/2005 4:13 PM
you could also try some of the epoxy putty that you can buy at home depot or others,,have used this stuff for a lot of stuff, it will form as hard as steel.used it about 15 yrs ago on my 70 international to fix a leak on the gas tank,, it is still sealed,,,,,easy to use, roll it up and apply...regards..Fred
Redryder pix
My Hotrod
#244007 03/21/2005 5:54 PM
As Joker said, first try epoxy putty, unless the crack runs right to the drain plug (then try welding and clean out the plug grooves). As Paul Harvey says, as a first resort, try JB Weld.
Tim
#244008 03/21/2005 11:02 PM
That putty is good stuff, I put some around one of my tail pipes on my 52 that had broken into rather then go to a muffler shop,, it is still intact, that was about 2yrs ago when I met Cletis and Tonynweatherford at the Rio Vista meet, I keep it around the house all the time to repair stuff,,,Fred
Redryder pix
My Hotrod
#244009 03/22/2005 4:57 AM
Weeeeeeeeelllllllllllllllllll.
I dropped the tank and bought a welder, welded it then painted, reinstalled. Boy are my arms tired. The problem was it was parked at a house with a gravel driveway. No concrete anywhere. Man what a pain! Racing against the clock, the rain, not much fun. I have never been so nasty either.
Other than that it was cake.
Still leaks oil from the rear. Probably a seal.
More on Hotrodders
