| | | Forums66 Topics128,057 Posts1,055,816 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Looks like I HAVE to replace my oil pan gasket now. There is a huge crack in the pan just above the drain plug. Anyone near Nashville have a pan for sale? It's a 235 (1959) | | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | I dont have a pan but it will probably be weldable.
I like old trucks
| | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Cooooool! I hate buying parts for an engine I don't want to keep. I will fix it with my friensd trusty wire feed welder. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you could also try some of the epoxy putty that you can buy at home depot or others,,have used this stuff for a lot of stuff, it will form as hard as steel.used it about 15 yrs ago on my 70 international to fix a leak on the gas tank,, it is still sealed,,,,,easy to use, roll it up and apply...regards..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As Joker said, first try epoxy putty, unless the crack runs right to the drain plug (then try welding and clean out the plug grooves). As Paul Harvey says, as a first resort, try JB Weld.
Tim | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | That putty is good stuff, I put some around one of my tail pipes on my 52 that had broken into rather then go to a muffler shop,, it is still intact, that was about 2yrs ago when I met Cletis and Tonynweatherford at the Rio Vista meet, I keep it around the house all the time to repair stuff,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Weeeeeeeeelllllllllllllllllll. I dropped the tank and bought a welder, welded it then painted, reinstalled. Boy are my arms tired. The problem was it was parked at a house with a gravel driveway. No concrete anywhere. Man what a pain! Racing against the clock, the rain, not much fun. I have never been so nasty either.
Other than that it was cake. Still leaks oil from the rear. Probably a seal. | | |
