| | | Forums66 Topics128,151 Posts1,057,003 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Ray Stanley, our own Metal Man has the patch panels which most 'burb and panel owners need for the area behind the door and the lower rear quarter corners. Check out eBay item #2495855633 and item #2495307240. These panels have all the right curves and formed beads to match the areas most commonly rotted out. If you can put your had inside the rear corners or behind the doors, better call Ray!  | | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | Very good looking corners!!!
Buddy | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Dude, where were you when I was fabricating in my garage this June. I had to cut away a great deal of my Suburban rear fenders. Couldn't find panels anywhere. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I just bid on some suburban parts on eBay, had the high bid, and then minutes later didn't. Then I looked to see who the bidder was. Okay SplashOil, you were there first, I'll let you have them...
MetalMan, I just sent you an email.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | I used sheetmetal and just formed it as close as possible. Spot welding, gringing and body filler followed. It took more body filler than I would have liked. | | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | Good question TM2. Any longggggg panel corners in the future MM ? I have a 3800 panel with a bad cab. I plan to cut off the rear end and make an AD fleetside bed for the 55.1. The only bad part or those longgggg corners.
Buddy | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Buddy in AK: I plan to cut off the rear end and make an AD fleetside bed for the 55.1. I've been thinking about doing the same thing. I've seen it done on a 1/2-ton, but I'm playing with the idea of using a 1-ton and building an extended cab dually. Then I may also need those long corners...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2002 Posts: 28 Junior Member | | Junior Member Joined: Jan 2002 Posts: 28 | Just saw this tread and had to chime in. Hey Metal Man, are you making any panels for the 41-46 burbs? I have a 45 that will be needing some sheetmetal next spring.....
Grant 50 GMC 45 Burb | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | how about the TF series? that's what Garrett has, and me too - wish I'd had some good patches for a number of things!!
Bill | | |
