6 members (68ironhead, Oswald, DHedrick, 3B, Gdads51, 1 invisible), 74 guests, and 4 robots.
Topics128,151
Posts1,057,009
Members48,460
Ray Stanley, our own Metal Man has the patch panels which most 'burb and panel owners need for the area behind the door and the lower rear quarter corners.
Check out eBay item #2495855633 and item #2495307240.
These panels have all the right curves and formed beads to match the areas most commonly rotted out. If you can put your had inside the rear corners or behind the doors, better call Ray! grin
Very good looking corners!!!
Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
Dude, where were you when I was fabricating in my garage this June. I had to cut away a great deal of my Suburban rear fenders. Couldn't find panels anywhere.
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
I just bid on some suburban parts on eBay, had the high bid, and then minutes later didn't. Then I looked to see who the bidder was. Okay SplashOil, you were there first, I'll let you have them...
MetalMan, I just sent you an email.
I used sheetmetal and just formed it as close as possible. Spot welding, gringing and body filler followed. It took more body filler than I would have liked.
More on Hotrodders
Good question TM2. Any longggggg panel corners in the future MM ? I have a 3800 panel with a bad cab. I plan to cut off the rear end and make an AD fleetside bed for the 55.1. The only bad part or those longgggg corners.
Buddy
'50 GMC Suburban
Quote
I've been thinking about doing the same thing. I've seen it done on a 1/2-ton, but I'm playing with the idea of using a 1-ton and building an extended cab dually.
Then I may also need those long corners...
Junior Member
Junior Member
Just saw this tread and had to chime in. Hey Metal Man, are you making any panels for the 41-46 burbs? I have a 45 that will be needing some sheetmetal next spring.....
Grant
50 GMC
45 Burb
how about the TF series? that's what Garrett has, and me too - wish I'd had some good patches for a number of things!!
