0 members (),
348
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Wondering if I have solid or hydraulic lifters. By the sound of it I hope their solid. If so they probably need adjusting. It's a 59 235 | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | I think all the 235's had hydraulic lifters by 59, if it's got the original engine. Does it rattle all the time, or change note warm or cold? Don't try to adjust the lifters while the engine's running. It just makes a big mess, and frustrates the mchanic! There's a good procedure to do an adjustment on a warm, stopped engine that works just about every time. Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | garretthes, All 235/261 truck USA engines (through 1962) had mechanical/solid lifters. V8 truck engines had hydraulic lifters. Automobile 235 engines with Powerglide transmissions had hydraulic lifters starting in 1953. I am not sure about the lifters in standard transmission 235s in automobiles from 1954-1962. I think there was a 261 engine in Canadian Pontiacs that had hydraulic lifters. In the Tech Tips section of this site are a couple articles on adjusting 216/235/261 lifters. Here is a another link on adjusting valve lash. Tim | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Should I even mess with the lifters? I sort of want to. It's a challenge. Something I've never done before. If I knew it would make a difference on the performance of the engine..... | | |
