| | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Kelly (wife) wanted to go to Sams a few nights ago so I suggested we take the 59 Suburban. She didn't want an adventure she said.....just to go to Sams. I assured her things where different now. The old truck was being forged almost daily into a dependable driver. OK So we are driving along on a 2 lane road at night on our way to Sams when I decided to switch the high beams on. Instead of the high beams I got a complete blackout going 40 mph. This was not what I expected and certainly not what Kelly desired. As she firmly gripped anything close I jostled the headlight switch until I finally got the lights back on. This "short" happened a few other times that night. Anybody have a good idea as to the probable source of the problem? My guess is the switch. | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Did it only happen when using the high beam switch? If so, I'd suspect the high beam switch. If, on the other hand it was happening when turning the headlights on or off, I'd suspect the light switch. High beam switches, because they are exposed to so much water, dirt, etc. are often the culprit. Also, before spending a lot of time on the switches, check the wiring and wire connections.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Have you resolved this?
The headlight switch has circuit breaker in it that might have become weak, or maybe you've got upgraded headlights that overcome the circuit breaker.
You may want to use a relay for the headlights, or get a newer headlight switch that can handle more amps.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | See new thread-Headlight switch removal | | |
