| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2003 Posts: 33 Junior Member | | Junior Member Joined: Aug 2003 Posts: 33 | I am thinging about installing some stainless steel king pin with needle bearing from ssbrakes. Is anybody using them ? They say no-machine work is needed. It going under my 48 gmc 1/2 panel, I plan on running a stock size wheel.
Stock and loveing it.
| | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i got some for my ****,but i haven't installed them yet.they seem to be good quality.im replacing mine to make it steer easier,not because they were worn out. | | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | Make sure you use a press it put them in. Don't think they will survive the HAMMER | | | | | Joined: Aug 2003 Posts: 33 Junior Member | | Junior Member Joined: Aug 2003 Posts: 33 | I have been told they would make it steer alot easier. And mine are just about worn out. What do you know about old style tie rod ends (stock) vs the newer all one piece style. I have been told they also help, but the are shorter, so it off to the shop for a proper adjustment.
