0 members (), 155 guests, and 4 robots.
Topics128,110
Posts1,056,241
Members48,437
#2433 12/21/2004 11:19 PM
Hi All,
I had my 4 speed in my 1948 Chev 1/2T rebuilt over 5000 miles ago, and today driving home from work I put in the clutch to down-shift into third, and I could not get the trans to shift out of 4th. When trying to move the lever, I got a "synchro" noise that you would normally get down-shifting, but I could not get it to come out of 4th gear. I limped it home in fourth with a little clutch slipping action. It now sits in the driveway awaiting me to investigate.
Are there any other ideas before I tear the interior out, and pull the floor pan and trans top to investigate?
Thanks in advance, Garry K
Garry K in Pac Nor West
1948 Chevy PU 235 SM420 4 spd
1932 **** B pu
1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
#2434 12/23/2004 5:18 AM
Garry I don't know if this will help mate but on my 41 with the four speed, I can't get it in to 3rd or 4th on the upshift or into 3rd from 4th on the downshift unless I slightly lift the reverse lock lever while changing gear. The spring on the lever must be either weak or missing. Like I said I don't know if it will help but might at least be worth a try.
All the best
Bob
#2435 12/23/2004 5:20 AM
Garry the only other thing I can think of is to check the oil level in the box. Good luck. I'm sure one of the other guys will chime in.
Bob
#2436 12/23/2004 5:58 AM
It sounds like one or more of the spring-loaded tabs on the 3-4 synchronizer has slipped out of place, locking it in 4th. gear. It's not an uncommon situation, which usually happens when someone assembles the synchronizer slightly wrong. I hope it won't take a full teardown to fix it, but it's a possibility.
#2437 12/27/2004 9:28 PM
Hey Garry any update on the gearbox problem?
Mozzie
